21 - 40 of 57 Posts
In F30, you have to flash KOMBI and FEM_BODY, so as long as you flashed KOMBI, FRM, CAS, and JBBF, you have done the equivalent.
Does it work in new F1x's too or only new F3x/F8x?
Works in my 2014 f10 m5 after I flashed kombi with 54.1
In F1x not M5 only flash kombi with last I-Step not enough.
A friend of mine doesn't appear on 6WB (retrofit), kombi have last I-Step, whole car no
Shawn in my car 0911 appear in display (1211 has remained for 6WB)
Discussion starter · #24 ·
Hello!
Hmmm, that is a thing I don't have to understand. Where they hide this damn function? It's not really necessary to survive but nice to have. :)
CU Oliver
Discussion starter · #25 ·
Hello!
One thing more. I can confirm that the function works for cars built >=07/2013 and i-step >=54.1. For cars with a built date before 07/2013 I saw it only in combination with the 6WB and >=54.1. Or is here anybody who has a car built before 07/2013 with a 6WA and has this display text?
I took a szl cafd from a F13 and compared it with my cafd. The number is the same, also the settings. Only one thing is different. CTRL_HOD_CODG_LVARCODE is 255 for F13 and 240 for my M5. But I think that's only a different type of the steering wheel.
CU Oliver
Hello!
CU Oliver
soon as I can try 6WA.
I looked in my CAFD of SZL, in CTRL_HOD_CODG_LVARCODE, Werte is 0A, for F13 OD :tsk:
I have a 2015 F25 US and there is NO indicator on the dash at all. Only have to peer all the way around to the side of the steering wheel to see the light. Can this be turned show on the dash? If so, what are the codes to do so? TIA.
Same here... No confirmation at all on F25 LCI. Would like to have this warning..!
Ouch :(
I am using E-Sys and 55.4 lite.
So naturally, here are my questions :)
1) Where can i get PszData full?
2) Is it dangerous to do this on my own?
3) If not dangerous, then can you please step me through the process?
Thanks Shawn.
There is always some risk when flashing ECU that you could brick it.
PM sent.
On pre-lci F10 with 6wb I have this message...
Car is build June 2013.
Then I have LED headlights from LCI, and steering wheel from M5 LCI.
Works great.
The only trick I'm doing to launch all those retrofits - is to code FRM with FA with another model code and zeitkriterium (July 2013 and LCI model code).
And then I manually code parameter something_INSCENIRUNG to be able to bring back assistance systems like ACC and others.
All others ECUs are coded with normal FA.
In such configuration message about steering wheel heating appeared without any additional codings and etc.
a would agree, it started somewhere on psdzdata 53 or 54. Currently whole car is on 55.4 and works great.
So, good luck to everyone.
You mean FAS_INSZENIERUNG?
Assuming so, what do you set it to afterwards?
21 - 40 of 57 Posts
