RFT's can literally be a life saver if you have a blowout in a place where it's not safe to change a tire. I used to drive the urban interstates of the northeast. I remember thinking "I'd hate to have a blowout here."
But, relatively few tire deflations are blowouts. Most are slow leaks, and modern TPMS's usually give you plenty of warning that there's a problem that needs your attention. I suspect that a lot of blowouts started out as a slow leak, where the lack of TPMS allowed the slow leak to turn into a blowout without warning.
I've driven about 1M miles in my life, and I've only had one blowout. It wasn't caused by a puncture, but by a rubber valve stem failure. TPMS's incorporate metal valve stems. So, the cause of my one blowout is now eliminated. We were discussing this last week at lunch. Two of my lunchmates, both in their mid to late 50's, said they'd had one and two blowouts in their lives. Between metal valve stems and TPMS, the chance of having a blowout is less than it used to be.
RFT's are a benefit to car manufacturers, because they don't have to include a spare tire. That saves money, weight, and volume. BMW often fills the volume where the spare would have gone with third row seats (X5), batteries for hybrid's, or large, low-back-pressure mufflers (M cars).
RFT's have some type of marking. Bridgestone calls them "RSC's." Michelin calls them "ZP's." There's also a "RUNFLAT" marking on the sidewalls. If your BMW has the original tires, and it doesn't have a spare tire, and it's not an M car, it's a good bet they're RFT's.
