DME programing abort
4341 Views 26 Replies 7 Participants Last post by  koutsouk
4
Hi,
my friend try to flash his DME, but it abort on BTLD flash with 0%.
I want to help him, because I fix alot of problems right now for people, but in this case i dont know how can I help them.
I try already to reflash the ecu again. One BTLD is visible and one SWFL flashing are completeted without errors.
FA, SVT (VCM/ECU) backups are available.
Did he need a new DME or what can I do for him?
The HKL error is since the i-Stufe update at BMW and not necessary in this case.
Thanks for help.
\\Editor: Problem solved via TAL-Editor.
See less See more
1 - 20 of 27 Posts
Hi,
Thanks for help.
hi Problem solved via TAL-Editor;
what are you changed in TAL-editor, please ?
thx
What happens when you calculate and start flash?
TAL execution started.
ExecutionID=2021/04/09-10:31:45.005
[] prepareTALExecution started [PROGRESS]
[] prepareTALExecution finished [PROGRESS]
[] prepareVehicleForCoding started [PROGRESS]
[] prepareVehicleForCoding finished [PROGRESS]
[DME - 12] prepareECUforCoding started [PROGRESS]
[DME - 12] prepareECUforCoding error [PROGRESS]
[] SVK-Ist does not match expected SGBMIDs for ecu ECUId: DME_0x12.
Excpected (relevant process classes only):
[hwel_00000a09-001_006_002, btld_00001218-006_027_000, swfl_0000121a-108_021_000,
swfl_000037b5-108_021_007], Actual (relevant process classes only):
[hwel_00000a09-001_006_002, btld_00000a0a-006_027_000, unkn_00000000-000_000_000, unkn_00000000-000_000_000], Missing SGBMID(s): [btld_00001218-006_027_000, swfl_0000121a-108_021_000, swfl_000037b5-108_021_007], Surplus SGBMID(s): [btld_00000a0a-006_027_000, unkn_00000000-000_000_000, unkn_00000000-000_000_000] [THROWABLE]
[DME - 12] There was an error during TAL execution, please check the log files. [WARN]
[DME - 12] - [Exception - DME - 12] SVK-Ist does not match expected
SGBMIDs for ecu ECUId: DME_0x12. Excpected (relevant process classes only):
[DME - 12] finalizeECUCoding started [PROGRESS]
[DME - 12] finalizeECUCoding finished [PROGRESS]
[] finalizeVehicleCoding started [PROGRESS]
[] finalizeVehicleCoding finished [PROGRESS]
[] finalizeTALExecution started [PROGRESS]
[] finalizeTALExecution finished [PROGRESS]
TAL execution finished [TAL_EXECUTION_FINISHED]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "9s". [C206]
this is a logs,
I have already tried a lot of things that don't work.
See less See more
3
Hwel seems different from your istep
ista-d
1037852
when i read ecu
1037853
when i calculate
1037854
See less See more
you talk about 'istep-taget" ?
What esys version and psdzdata are you using?
esys 3.30
i tested, psdzdata 4.10.21 ; 4.22.25 and 4.24.31.
Is this original Ecu or replaced?
original ecu i had a bug with programming with ista-d, since, it's like that.
can i have a look with teamviewer? Bootloader is strange.
i dont have team view,
i have a question,
if hwel is black, is it necessarily the right one? or can I replace it with another?
1 - 20 of 27 Posts
