1 - 4 of 4 Posts
My car is a 2001 330ci with 108,000 miles on it. End of November 2010 at 105,000 miles the oil was changed; end of February 2010 at 108,000 miles it needed two quarts and I put in what the mechanic recommended: Mobil 1 5w30 synthetic. What is normal oil consumption, or the factors that make "normal" difficult to establish? The car has never leaked oil when parked.
Tar Heel Faithful
Technically that falls within what BMW defines as normal: 1 litre every 2000km (1200mi). However in your case, it still sounds like a lot especially for the M54 engine. Generally oil consumption is determined by driving style and atmospheric conditions- if you're regularly tracking the car or running high rpms, then oil consumption will be higher than in a mostly-freeway, lower rpm driving style.
Mobil1 5w30 isn't the proper oil for the m54 - too thin. Use mobil1 0w40 or better yet, castrol 0w-30. Several members at e46fanatics have indicated the latter helped their oil consumption issues
My 2001 330ci burns a quart every 2k miles, has 132K on it now and has used that much oil since I bought it in 2004 with 53k on it.
I use BMW 5w30 oil since it is per spec and I get a case of it plus a filter for $77 dollars - with my BMW Car Club discount.
A few items can actually be competitive in price, from the dealership, with the 15% off...and occasionally they swing me a 20% discount.
1 - 4 of 4 Posts
