Not really a requirement, though it is recommended by BMW/Bentley/etc. When was the last time you had it done?Having my lower arm bushings replaced. Will I now neeed a front end alignment for my 2002 325i?
About a month ago...all four corners. Also, reason I'm asking about the alignment is that I was wondering if my extended warranty will cover it. My thought is that if it is more than just the busshing replacement, then alignment should also be an integral part of doing the job correctly.Not really a requirement, though it is recommended by BMW/Bentley/etc. When was the last time you had it done?
Depending on that answer, it might be a good idea....
Wouldn't bother then. The mounts have holes that position themselves on the car. Properly installed there should be little-to-no movement.About a month ago...all four corners.
I've replaced the control arms and bushings months ago. My steering wheel is still centered and tire wear perfectly even. So no alignment so far. Replaced rear shocks with bilstein HD's two weeks ago and yesterday the front driver's side struts. Surprisingly, the steering wheel is still centered and the car seems to track in a straight line.Having my lower arm bushings replaced. Will I now neeed a front end alignment for my 2002 325i?
If you do control arms and don't get an alignment you are asking for trouble. I did this and it ate my tires because of toe. Car tracked straight and the wheel was centered, but that isn't a good litmus test.I've replaced the control arms and bushings months ago. My steering wheel is still centered and tire wear perfectly even. So no alignment so far. Replaced rear shocks with bilstein HD's two weeks ago and yesterday the front driver's side struts. Surprisingly, the steering wheel is still centered and the car seems to track in a straight line.
So with just your bushings, I certainly doubt you need it.
