do M3's come in automatic
14805 Views 46 Replies 11 Participants Last post by  nate
hey i was just wondering if M3's come in automatic or only stick?
1 - 20 of 47 Posts
yes, both the E36 M3/4 and the E46 M3 are available with automatic transmissions.
thanks
do u also know how much slower it is in automatic....like to 60?
E46 M3 is not
At some point, all E36 M3 body styles were offered in auto
nate328Ci said:
E46 M3 is not
The E46 automatic is called "SMG". :D
See less See more
SMG IS NOT AN AUTOMATIC :mad:
Someone who does not know how to drive a stick will have NO problems driving an E46 M3 with SMGII. Nothing to learn, no damage to the internals.
I think that's probably what he needed to know.
:flipoff:
See less See more
:flipoff:
That doesn't make it an automatic :rolleyes:
Automatics are not manuals with computer controlled clutches, they don't shift in 0.08 seconds on driver demand or blip the throttle when decelerating :thumb:
See less See more
manual w/o clutch pedal that is :D
I'll take that :thumb:
But Nate, that is only when you are in S6 mode!
When you are in A mode, the car does EVERYTHING for you....
AUTOMATICALLY!!!!
See less See more
so does it come in automatic...or is that smg thing the same as automatic?
SMG has 2 modes: Austomatic (A) and Sequential (S). In either mode, their is no clutch pedal. If you have never driven a stick before, you will still be able to drive and SMG-equipped M3 with no troubles.
AUTOMATICALLY!!!!
It will blip the trottle in any mode...
Automatics have torque converters, creep, and are not based on manual transmissions
SMG is NOT AN AUTOMATIC TRANSMISSION. Remember SMG 1 was offerend on the E36 M3 at the same time automatics were, it wasn't called automatic stage 2 or something.
SMG is manual based, with computer controlled shifts, it is not a fancy auto. SMG shifts faster and perfectly, I can't, nor can professional race drivers. It is the superior transmission.
Fine, don't call it manual, but it isn't an automatic.
See less See more
So explain what 'A' mode stands for :D
(Nate--you know that I know all there is to know about SMG II. Why so sensitive about it?)
See less See more
5
And I still think my point is valid. His question belied the fact that he doesn't know how to drive a stick shift. He will have no troubles driving an M3 with SMG.
If you can call it an automatic because it has A mode, why can't it be called a Manual because it has a manual mode?
It isn't an automatic :dunno:
See less See more
I was referring to the 80ms shifts. :p
See less See more
I agree with Nate; SMG is about as Automatic as hamburger is a pork chop. They're both meat, they both taste good but they're from 2 different animals and are made differently.
SMG can operate automatically but is NOT AN AUTOMATIC TRANSMISSION.
There is no manual mode.
(S=sequential)
:lmao: :lmao: :lmao: :lmao: :lmao: :lmao:
See less See more
1 - 20 of 47 Posts
