After hours of research and finally getting my hands on a cable and the car that I'm wanting to code on (my cousin's), I finally managed to have a go at setting up the BMW Coding Tools with INPA and NCS Expert, but so far have had no luck getting either to work, even after three different attempts. Atm I can't even get the two black circles in INPA to show, so I'm guessing that the problem is the connection. I've done everything listed to setup NCS Expert and configure the cable on every tutorial I can find, including changing the settings in Device Manager, but no matter what I try can't seem to get it working, which makes me the think that the cable itself might be problematic. The cable was fairly cheap, around £15, and am wondering whether it's one of those that need to be modified before it'll connect.
Here is the cable: http://www.ebay.co.uk/itm/331789200109
And I've attached pictures of the circuit board inside it.
Will it need to be modified, and if so, what exactly is the process for modifying it?
