21 - 30 of 30 Posts
Discussion Starter #21
Here is a picture of where the vent is on when under the car:
There is very, very little room.
Here is what I used to slowly open up the vent:
The I was able to get the wire in about 3/4", after much wiggling.
After the next long drive, I will crawl under my car, and remove the fill plug and check for pressure build up. I am 90% sure the vent is now opened up.
Discussion Starter #22
ahhhhhh......... and now i see why we are here..
because we think the diff is leaking because the "vent" is clogged...
may i ask where your leaking from? (there is only 6 spots it can leak from)
driveshaft input seal, axle left axle right rear diff cover gasket fill and drain
Leak may be too strong wording... more like a sweat... between the the diff and cover.
Under the lift arms
I was only saying bee because im getting nasty pm from some guy here calling me out about the vent and how im wrong
what i was getting at is the fact that we are here talking about a leaking diff (WHICH DOES HAPPEN) and is quite normal... but its nothing to do with a hypothetical plugged vent"
max... drain your dif on level ground.. support the rear dif with a jack drop the cover, inspect your hole replace the cover with a new pumpkin gasket your leak will go away...
Discussion Starter #25
It is not enough to worry about right now.
PLUS in the last month I have spent more time under the car and under the hood than driving it. (rad, water pump, thermostat, expansion tank, front thrust arms, alternator, drive shaft and support bearing, all 4 rear control arms, ball joints and rear end links...)
Discussion Starter #26
Without a doubt the diff IS vented. My pressure build up is gone. I went for a 1 hour drive to warm up the diff. When I got home, I removed the fill plug and nothing happened.
Also, look at the diff cover on this Z3: (note small hole on the upper right?
M3 Diff:
Or how about this E38 diff:
For those that think the small hole is not a vent, look at this X5 diff:
(A breather tube attaches to the top right tube to prevent water from getting into the diff when going off road.
Way to go, Max!
The Instant Canonical Pumpkin Venting Thread! (In more ways than you'dda thunk....)
[edit]
One thing I keep forgetting to ask out loud ... the top of the vent channel, is it solid aluminum or perhaps a freeze cap of sorts covering a hole that would allow one to fit a larger vent tube?
Discussion Starter #30
Is the top of the vent channel, is it solid aluminum or perhaps a freeze cap of sorts covering a hole that would allow one to fit a larger vent tube?
it looks like a freeze plug. I will post pics later from when I removed my subframe.
21 - 30 of 30 Posts
