1 - 10 of 10 Posts
OK, so some questions for you mechanical types out there.
When at highway speeds, my car seems to pull SLIGHTLY to the right and if I let go of the steering wheel on a straight road, the steering wheel angles slightly to the right.
However, it also seems like the steering is really sensitive to banked and crowned roads, and maybe I'm just being overcritical. But I swear the car just doesn't have that "dead center straight ahead" feeling like it used to.
Am I just being too AR? It is IS the alignment, would it be covered under the car's full maintenance program?
Thanks in advance for your input!
Head-In-Sand Dumbass
No it's not covered, but it could easily be your tire pressures causing the symptoms you're describing. Check em out and let us know. BTW nice color!
Rest in peace, Coach
It is up to 1,200 miles.
Discussion Starter · #6 ·
Yeah, this was the 1st thing I suspected too. I checked the tire pressures and did have to make some minor corrections, but the problem persisted even afterwards.
BTW nice color!
Gotta luv that Topaz! Actually, you and Vince were my lifelines over at the .Org while I was waiting for my car. I always had something to drool over until I picked mine up. :D
Discussion Starter · #7 ·
dredmo said:
nope no warranty, my cars pulls and stuff, it could be potentially a brake problem too.
edit: if it is a brake problem, they will fix that
Funny you should mention that, because I have felt like the steering wheel pulls "back to center" when I apply the brakes.
Damn, 16,600 miles too late. :(
Well, I have an appointment next week for the sticky pedal fix, so I'll have them take a look at it then and let y'all know what I find out.
Haha, yeah I keep finding all these closet topaz freaks everywhere. I was/am one myself. :D
Good luck and make sure you get a good feel for your current sticky pedal because you aren't going to believe the difference with the new parts! It's awesome!
I have the same prob.
What size rims are you running and what tires? If you checked tire pressure then alignment would be next step. Then tire balance would be last. After having mine aligned it still slightly pulls to the right(I've noticed it affefcts people with plus size wheel/tires- I have 225/40/18s.
Discussion Starter · #10 ·
Re: Re: Does the "Full Maintenance" program cover alignment?
Standard Type 44s: 17 x 8.0 wearing 225/45 WR 17s.
It'll be interesting to see what the dealer has to say about all this. Good point about the tire balance though. I had a flat awhile back and had to have some tires moved around (Long story). I wonder if they re-balanced when they moved the tires.
Thanks for all the advice, guys. That's what this forum is all about! :thumbup:
1 - 10 of 10 Posts
