1 - 11 of 11 Posts
Everything's Bigger in TX
Is your hood closed all the way? I know that on my old Volvo, that was a common issue. The car would lock, but not signal. Since there are two latches on this car, and I've seen cars with only 1/2 closed hoods in pictures on here, I wonder if it could be the same...
Discussion Starter · #3 ·
no beep-beep
Tried closing the hood. But it still does not have the beep-beep when I lock. Such a pain if I have to take it in...and I would just because I don't know if something else might not be working...like the airbags! If anyone has suggestions, please let me know.:tsk:
Did you accidentally turn it off in the settings menu?
This happened to me when I refilled the washer fluid. Try re losing the hood again and starting the car. After that it worked fine.
Same thing here! Just tried reclosing hood and still no luck, I forget when exactly it stopped working but now I wonder if this was after I installed the black kidney grills.
I'm having the same problem now. I double checked the settings and opened and closed the hood a couple of times and still no chime - the lights flash alright. Is there a fuse on this circuit? If so, where is it? Where is the gadget that chimes? Can it be easiy replaced? Does anyone know anything about this?
Thanks. Taking the car to the dealer is something I don't want to do so if that is the only fix I guess I'm going to have to live without the chime. Is "code upgrade" some form of software update?
The Driver
This is the most likely explanation. I have mine turned off deliberately.
1 - 11 of 11 Posts
