1 - 7 of 7 Posts
Hello All,
My drivers door no longer opens correctly.
If I simply pull on the handle the door mechanism does not release.
I must now push the door in and while doing so... pull on the handle .... and the door then opens.
I know little about the inner assembly/workings of the door mechanism.
Any suggestions/fixes?
Thanking you all in adance
Peace,
D
Investigative Tinkerer
Try a "smear" of grease on the striker pin (doorjamb).
Screawed
Check that all set screaws are in all the way if one backed out a little it will throw the strike off!
Token Canadian
interesting....got exactly the same problem with a 97 Z3
and if it ever stops raining I'll test out these suggestions :)
had the same problem too. I was going to post about it, but the mechanics fixed it during the routine inspection. Good to know some solutions for next time.
The Anti-Rice
Just grease the pin and the lock and it will be fine.
This is common to just about every E36 coupe out there.
1 - 7 of 7 Posts
