1 - 3 of 3 Posts
Hello
What gear do u drive inn while pulling heavy trailer? whit the GM transmission X5 Diesel.
I have heard that it is best to be in S and not D because the transmission do not produce so much heat in S.
don't know about S vs D
but
if you are pulling often
it's probably a good idea to invest in an extra cooler anyway
couldn't hurt
Having towed quite a bit I suggest the following for engine and trans longevity:
When your speed varies like stop and go traffic and around town: S
Constant speed on flat highway: D (better milage when S not needed)
Uphill on highway: S
Downhill on highway: D (unless you are constantly on brakes then switch to S to lower the gear to take advantage of some engine braking).
On snow: D with a light throttle as possible.
1 - 3 of 3 Posts
