[SOLVED] Driveline issues - STUMPED any help would be appreciated.
Hi guys, I've had one or two driveline problems for the last month that I've chased and chased, and now I'm stuck and my wits end trying to diagnose this thing. :banghead:
Any help/input would be much appreciated.
So about a month ago, my 2004 325i wagon (auto) started to develop a shudder during initial acceleration under load (from a stop). If i eased into the pedal it was fine, but if I accelerated normally, the rear end would shudder pretty hard. Got under the car to find the bearing on the csb was completely separated from the metal band so I changed the csb, guibo, and centering sleeve on the drive shaft, and the problem seemed to be almost completely gone. there was still, however a very slight shudder.
^Around this time I also had the rear wheel-bearings replaced
two weeks ago, the car started to develop a droning/vibrating sound when coasting, if I got up to 55+ mph and let off the gas, the vibration would get louder and louder until it felt like the car was driving on rumble strips around 30-45mph, below 30 it got quieter and above 45 it was quieter but the vibration never really goes away unless i'm on the gas pedal. If i'm half-way on the gas, the vibration diminishes but is never completely gone unless i'm 60% or more on the gas.
So i got back under the car, this time noticed the half shafts had ruptured and sprayed grease all over the inside of the wheel hub. I replaced the half-shafts but the problem is still there, and the shudder that used to happen under load from a stop seems to have returned.
Changed trans fluid, changed rear diff fluid. Problem still the same.
Both fluids seamed fine, no metal shavings or terribly black fluid or anything.
Also checked to see if brakes are dragging and they are not. (coasted to a stop touched rotors, none of them were warm/hot.)
I got back under the car, attempting to diagnose the U-joints, there is almost no rotation-play in the driveline if the car is in park, and absolutely no play if i'm trying to push/pull the driveline fore/aft near the U-joints. Doing some more reseach I did realize two things:
I re-used the guibo bolts, but they still seem tight. There is no play in the guibo.
I did not however, mark the position of the old CSB before i put the new one on (but i did mark the drive shaft).
I did notice the transmission mounts are shot.
So my question now is... could the vibration be the rear differential going bad? And why did the shudder under load come back?
I'm out of ideas and now turn to the community for help. Any input or feedback is extremely appreciated, thank you for reading.
