1 - 17 of 17 Posts
When I turn both zones up to 84 deg (max), and blower all the way up the driver side is blowing cool & passenger side blowing warm.
A couple weeks ago, I did replace my coolant expansion tank. Drained the coolant and filled with new.
Air caught in the lines somewhere?
BMW X5 e70 35i
Nuclear engineer
Nope. Assymetrical heating suggests failed Hot-water Control Valve - HCV.
IHKA is a hot-water temperature controlled system. The AC / evaporator is ALWAYS fully loaded (unless compressor overrriden off) and the temperature is controlled by IHKA ***8216;computer***8217; controlled HCV.
Discussion Starter #3
Thanks Doug,
Is that the same as Heater Control Valve?
Before looking for faulty parts, did you check the driver and passenger vent settings in the idrive menu?
Discussion Starter #6
So I adjusted the idrive settings and seemed to work for a short time. I plugged in my Carly and there’s no error code for HCV.. stumped
Nuclear engineer
Pretty sure HCV is dumb and can’t generate a code.
Nuclear engineer
Your IHKA generated a code. The HCV is merely PWM solenoids.
Discussion Starter #12
So.. one more question, is the Hot Water Control Valve the same as the Heater Control Valve?
Driver side blowing cool & passenger side blowing warm
Doug is the IHKA guy but from what I understand, you can always unplug the connector to the HCV. It is designed to need power to close. If unplugged you should have max heat in all vents because it will be open. If it does give you high heat in all vents when unplugged then it should mean it is working. If air stays cold on one side as you describe it I believe that points to the HCV being bad.
Nuclear engineer
I believe that the HCV is normally open NO powered shut with PWM variable duty cycle. There are pictures here on BF of dissected HCV.
Discussion Starter #17
Yep, so I unplugged the HCV and it’s still blowing cool air. Must be the issue. Thanks all!!
1 - 17 of 17 Posts
