1 - 2 of 2 Posts
Does anyone know what it costs or how hard it is to replace driveshaft or rebuild?
an indy shop said i need to have it done and not cheap!!
royster
thanks
This is the company that I used. Cost includes shipping your old driveshaft to them and shipping it back to you. Took a little longer on my 760 as it was a special build. However the 750/745 should be covered. In the listing. They also use a company/office in the Los Angeles area so it doesn't have to go to Texas if you're in California.
http://www.driveshaftspecialist.com/Import html/BMW.html
Rebuilding it could be very expensive if the shop tries to do it with just the parts and did not have the equipment. The universal joint cannot be taken apart without special tools. Other than that, taking the driveshaft out itself is a fairly simple operation. Also be advised that the cost of the replacement also includes a new center carrier bearing.
1 - 2 of 2 Posts
