7 series Drive Train Malfunction so far solved
I drive a 2009 750i.
I have been dealing with a drivetrain malfunction error for the second year, in the winter when the temperature is cold.
The dealer replaced the fuel injectors and ultimately it went away.
The errror resurfaced this year and obviously the injectors couldnt be the problem. Again, I only get the error when the temperature is cold and I left my car outside instead of the garage.
I did a lot of research online and tried the following after my research that something was probably freezing overnight.
I pressed the start button on my car without depressing the brake so that only the electrical was turned on.
Pulled the windshield wiper lever several times. Found that the water did not spray correctly. Likely because water had frozen in the spraying mechanism.
After a few pulls, water flowed freely.
Car started fine, without the error.
Just posting this after all of my frustration that it might help someone else. I will post another update in a couple weeks to see if this continues to solve the problem.
