Dude, your car's computer stores error codes....read 'emI have a 2011 535i xdrive. It has around 49k miles. I first got this light about a month ago once I was on the highway and started to accelerate. I drove home about 20 miles and turned car off. I turn it back on to go to my mechanic and warning lights gone. It doesn't come back until today. Same thing I'm on the highway doing around 65mph I go to accelerate and switch lanes and it came on again. Car feels fine it just obviously doesn't have same power while this warning light is on. Same story I park it today, leave it off 5 min. Turn it back on and boom everything back to normal car running greAt. Any idea what this could be? Is it a computer glitch?
Check the Carly App.So, if one were to get the "gold standard" Bavarian Technic hard/software that interfaces via USB to a laptop, could one then procure and upload software to goose a few performance parameters of the N55? I'm OK with this car's power, but not OK with interminable lag when quick throttle response is required at lower engine speeds.
Yeah, going to go have my mechanic take a look at it today.Dude, your car's computer stores error codes....read 'em
Interesting. Odd thing is mine were weeks apart but issue seems identical. I'll have to prob take it and hope it's not serious since I'm not under warranty.Just picked up my 2011 550i from the dealership. Drivetrain Malfunction 3 months after the CCP. Error popped up on acceleration entering the highway...next day, came on again during highway acceleration.
It was leaking vacuum hoses to the turbos. Replaced by dealership (warranty)
and so far so good today.
:thumbup:
Wow, as weird as this sounds I just tried it and you're right. Way different when my foot is fully flat on the pedal. Car takes off with no lag. No more Americano style for meCheck the Carly App.
Believe it or not, place your foot fully flat on the pedal; accelerate. There should be no lag 'cause BMW turbos are always on boost. Yep, always. BUT if you drive Americano style, right foot easy off the pedal, it'll slip as you push, leadin' to lurchin'. Also, especially N54, as intake valves foul smoothness suffers.
Ooof!
I could be wrong but, F series needs E-cable interface for high data transmission.
That is a K+DCAN cable for E-series. The OBDII part is correct, but you you need ENET (Ethernet) on other end for F-series.
So I ran a diagnostic at my mechanics and these are the faults that came up. What do you think? Do I need to get a new HPFP?BMW tech here,,,,sound like it might be a boost related problem,,,,you said it happens highway speeds accelerating,,,,check for any fault codes,,,,my blog page Bmwtechnician
So had my HPFP and low pressure fuel pump both replaced, and still the light comes back. My mechanic said he did hear a little ticking noise and thinks maybe as a last resort to try and change the Vanos solenoid. Any insight on this? I'm thinking about changing this last thing and then if it doesn't fix it, I'm dumping the car. It's barely got 51k miles and I can't deal with these issues like this. So annoying. Do you think changing the Vanos solenoid might just be what it was since I've read it has been the issue before? I was also told I may just need to get my computer reprogrammed?BMW tech here,,,,sound like it might be a boost related problem,,,,you said it happens highway speeds accelerating,,,,check for any fault codes,,,,my blog page Bmwtechnician
I can tell you this from my experience with the warning and also from the absolute pressure code. The valve cover needs to be replaced and you probably have vacuum leaks. It's possible you need a new low pressure fuel sensor, I've heard from those with 335i that the sensor is sometimes the issue and not the pumps.
But in addition to the valve cover, I had the injectors replaced and to be more specific for me #6 was basically dead. Everytime I would engage any sort of acceleration power I would get the error. Also of course I replaced my spark plugs. After the valve cover, injectors and plugs (I had to because #6 plug was somehow burnt) I'm running without the error no matter how hard I mash on the gas.
I also aside from the replaced some ignition coils as well but I did them one by one at different times during the year during my replacement of said things. Also have your mechanic run a smoke test and pressure test before he keeps on making money from you to be certain of valve cover, replacement, and or hoses replacement.
Well at this point testing to see if the fuel rail sensors are working properly wouldn't hurt. But other than that it seems there isn't much else to try other than the sensor and update the modulesView attachment 575274
These are the only codes left after replacing both the HPFP and the regular low pressure fuel pump. I have been told it can now be a computer issue and I should just get my computer module reprogrammed and see if that fixes it. If not, I'm going into the spark plugs and ignition coils.
How do you update the modules? Do I gotta go to bmw for this or is there any other way? And does anyone know how much they charge for updates?Well at this point testing to see if the fuel rail sensors are working properly wouldn't hurt. But other than that it seems there isn't much else to try other than the sensor and update the modules
