1 - 16 of 16 Posts
Hello, First post here on the E39 board. looks like a great source. I just sold my E34 and purchased a 2000 528i-a w/ Premuim Package 60K miles. Love it. Already looking at supension. HA!. I did not find too much info on a search but apparentley daytime running lights can be activated. Is this dealer activated only or can a good independant shop do this? I am assumming it is done by diagnostic/service computer. Any iinsight would be appreciated. Thx
Premium Member
Dealer only...Indy can most likely do it but call them first to make sure--they need to have the MODIC computer.
i'm pretty sure that you can do that with Carsoft and an ebay type interface. Its for the computer fiends though, getting the whole thing working I mean...
Drl
ChileBeam, can I do that on my 97 528i?? (get a discount on insurance for DRL):D
Premium Member
I'm pretty sure all E39s can have DRLs turned on...but you need a dealer's help.
Carsoft won't do it, I'm not sure about PA-Soft though.
Discussion Starter · #8 ·
Kind of a silly question but when activated, are the DRL's use the high beam headllight bulb at a resisted level?
Yes, DRL uses the high beams at lower voltage (making them yellowish also)
Car soft can change the door auto lock option, the clock (12 vs 24 hrs), display language and a couple more options. I couldn't find DRL there.
Tan
e39breyton said:
Can they deactivate the checking rear taillight bulbs too?
I believe that it's a dealer programmable option when you upgrade to rear LED's. The LCM calculates the resistor values of the lights and if they're not within specs, the error code's displayed.
that's weird because i upgraded to LEDs and i never got an error message for rear taillights...:dunno:
Some of the after-market celis packs have the resistors to provide correct value to the LCM
Premium Member
Tan
Errr, not quite. The voltage is the same...the current is lower. The DRLs are your high beams at approximately 30% power (or 30% current).
I originally wanted to tap into DRL for powering the halo lights (for touring), and the voltage I measured was about 3.8v or so, the same as side markers. That's why I think they drop the voltage, not current.
The side makers also use 3.8V for some strange reason (very odd voltage when looking bulbs in the stores)
Tan
1 - 16 of 16 Posts
