I have a 1987 325 coupe, (no e, es, i, is badge)
I just bought a new clutch for it when the it went out recently. I pulled the Tranny to find that the factory flywheel was a dual mass, and of course the clutch kit i purchased was for a single. After finding out that the Dual Mass type flywheels cannot be resurfaced i ordered a used single mass flywheel from Bavarian Auto Recycling in CA, Had it machined at a local shop, installed the flywheel with new 28mm bolts, new clutch along with several other wearable parts that are standard in a clutch job. Once i got it all back together i go to turn the key and it cranks strong, the starter turns the flywheel like normal with no unusual sounds, but it wont kick over.
I know that there are two different single mass flywheel types, one that has a weird tooth-like shaped contour on the pressure plate surface, where as the one that i bought has a completely smooth pressure place mounting surface.
The car actually did turn over and sort-of idle once or twice but almost as if only running on one or two cylinders with zero throttle response, after a few seconds of that i killed it.
I pulled the coil wire from the distributor and cranked it over again and there was no spark coming from the coil. This makes me look to the two Flywheel Sensors.
My first assumption is that the flywheel sensors might be different for cars with a dual mass flywheel vs those without?? Does anyone agree?
Has anyone Swapped the dual mass for a single and experienced a problem like this? Did i overlook something?
Thank you in advance for your help guys!
Anthony
Anthony
