1 - 2 of 2 Posts
I have a pressure too high front axle fault. According to the dealer the valve block needs to be replaced. As far as I have been able to find it looks like it is just a matter of getting a replacement block, new or used, get the car up in the air, remove some plastic and replace the block. Top up the fluid reservoir with CHF11S and run the start-up procedure within ISTA+ (I already have that running, but no experience with dynamic drive or the startup procedure). Is it as simple as it sounds?
I know that the start up procedure will not run with any faults detected - so that might be an issue. Can the car be fired up with a new valve block and no initialization?
1 - 2 of 2 Posts
