Hello all
I own a 1989 BMW E30 325is with the 5 speed manual. Right about at the start of July it randomly generated a misfire issue. the day before it was running great then overnight it acquired a miss.
I have spent almost the last two months trying to fix this issue all to no avail. Thus far I have replaced the fuel filter, ignition coil, injectors, and I changed out the electric plug coming from the firewall going to the electrical connectors for the fuel injectors with a water tight aftermarket one. On top of all this I have pulled all the spark plugs and tested them to make sure there was a good spark on each one (none of which showed any signs of a miss ie burnt ends) and I have done a compression test coming up with these results:
cylinder 1:170 2:170 3:170 4:170 5:168 6:165 The last thing I will mention here is that I have also checked the codes by turning the key to the ON position and stomping the gas pedal 5 times and watching the check engine light. The car consistently throws up the code 1223 which is supposed to be the coolant temp sensor although the temperature gauge seems to work fine
Some history on the vehicle:
Back at the end of May/early June (1 month before the miss problem started) I replaced the timing belt along with the accessory belts, distributor cap and rotor, spark plugs, and the water pump. After I got everything put back together the car ran fine and I continued to run it for all of June without problems however I should note that there was a consistent overheating issue and loss of coolant. The temp gauge would get to the 3/4 line and stay there unless I cruised at very low rpm's (around 1,000). During this time I also did a oil change as I found the oil level to be low and it was about due anyway.
More recently when I changed the ignition plug going to the electrical connectors for the injectors the miss disappeared however the temp gauge stopped working and my clever dad suggested that I may have got the two electrical connectors at the end of the electrical bar that connect to the coolant temp sensor messed up. Against my will my dad had me switch these two around and what do you know the miss came back and the temp gauge still didn't work! When I switched the electrical connectors around again the miss stayed as well as the temp gauge problem (Later on my dad fixed the temp gauge through unknown means).
Well that's about all the info I can think of to throw in besides that the car has about 170,000 miles on it. I'm out of ideas now and im considering taking it in to a repair shop or a dealership (really hope I don't have to do that though) to have them diagnose the problem so I can fix it. Any help would be greatly appreciated. Thanks again
