Hey guy this is my first BMW build so looking for input and resources for parts
I have an 86 325es 2.7 eta I bought the car with a turbo setup on it not sure what kind of turbo it is seems like a no name brand stainless header not sure of injectors the turbo went bad first off then skipped time on the belt so I pulled the head off no damage as far as valves but there's pits in the head from a piece of metal that went through it so I'm building a new engine this is what I need
Decent turbo the one that was on it made 18psi .60 trim looking for new or used
What kind of head gasket to use and where can I get it
Is there cams with grinds specific for turbo applications?
What kind of head bolts or studs should be used?
The block is staying stock bore and trying to do without cutting it for o-rings so the head gasket is important block is goin to be decked crank turned .10 undersized polished and knife cut rotating assmbley balanced intake and exhaust ports gasket matched head will be extrada honed next week and polished that's where I'm at so far tossing the idea around for water meth injection too. Any info would be great and if you have parts as far as a turbo let me know thanks everyone!
