I am looking to replace the dual mass fly wheel on my e34 530 I 5 speed.
I have seen a few options but I think I need a little more holding power. the last clutch only lasted 70k miles with only 5 k of my driving it hard. the clutch was slipping a little already when I got it. I assume with 232,000 miles the flywheel is due for replacement since I see not repair on that in the previous maintenance receipts.
I have been informed that an e39 535 v8 clutch will fit. but I may have to do something about the lip on it ?
ALSO hearing about e36 compatibility ?
also I don't know if the clutch release bearing is the same ?
http://www.bavauto.com/fland.asp?pa...-2003-612866&gclid=CLGew6-Arc0CFUo2gQod2usANw
$600
will the above work ?
after market performance
http://ttvracing.com/products/?manufacturers=bmw&engine=bmw-m60&type=flywheels
$700 plus minus
anyone else in my shoes presently ??
STOCK OPTION
http://www.bavauto.com/shop.asp
CLUTCH DISC ONLY
SO CHEAP
Also would installing the 540i E34 clutch have any benefit ?(better holding) would it even fit ?
$600
$700 plus minus
STOCK OPTION
CLUTCH DISC ONLY
SO CHEAP
