so the shifter that is currently in the E30 will not work? did you mean to say find the shifter from an E34?the transmission itself will work, but you will most likely need to find transmission crossmembers (wrong word?) and the shifter from an E30
sorry... i shouldnt have assumed this is for a manual conversion? is his car currently auto or manual? if it is currently auto and he wants manual, then he will need said parts. if it is currently manual, then you can use his current parts, and it will just be aa case of pulling the tranny from the E34so the shifter that is currently in the E30 will not work? did you mean to say find the shifter from an E34?
he has a manual already, so its just a straight swap?sorry... i shouldnt have assumed this is for a manual conversion? is his car currently auto or manual? if it is currently auto and he wants manual, then he will need said parts. if it is currently manual, then you can use his current parts, and it will just be aa case of pulling the tranny from the E34
yep. i would replace the consumables at the same time however. get an M20 clutch kit aswel. this is of course unless its recently been donehe has a manual already, so its just a straight swap?
