^ + 1
Yes, running your car OUT of FUEL can contribute to many issues..
GET GOOD FUEL FROM A TOP TIER STATION.. 91octane or BETTER.. Do not let the fuel drop below 1/16th.
It will overheat the fuel pump as HornHospital described above.
Also clean your MAF, and check air filter while you are checking for cracked, dry, or brittle rubber
when searching for vacuum leaks.
Cheers!
NOTE: dont let your buddy drive your BMW again.. :lmao: :roundel:
