So when I bought my 92 325i, it had this issue where sometimes when you completely press the clutch to the floor, it made this weird grinding sound. The previous owner gave me a new slave cylinder, so i decided to replace it. I removed the old one, put the new one on, and bled the system.
I dropped the car and tried to start it. It was in first at the time, and the car lurched forward even with the clutch all the way down. I took it out of first and now it won't go in gear at all. I tried to rebleed the slave cylinder and it didn't change anything. The shifter won't go in any gear, clutch in or out, and it doesn't matter if the car is running or not.
One thing I noticed is that in the hole where the slave cylinder piston went into, there was something loose. Did I break something or what?? I'm pretty sure it was the clutch fork but it's not exactly common for those to break?
