1 - 2 of 2 Posts
So im having some issues with my e36.. the attached image shows what im dealing with partially. This comes on with sounds going on like dings and my gauges do like a sweep and it does it a lot. Also im driving regularly and press the clutch in going from 4th gear to go to 5th and its a loud grind and i know im not mishifting because it happens to much and when im at an idle like at a red light after driving for 5-10mins smoke comes up from my shifter.. A little worried about whats going on. Luckily If its the transmission i have an extra one with 141k miles on it. Thanks ahead of time to everyone who helps me out
Dinggg....what now!
you gotta get it up on a lift and see wat's going under under there.i am guessing your gearbox is leaking oil and dripping it on the hot exhaust pipes.....
grinding cud be synchromesh.....check fluid level....
instrument cluster doing an uncommanded self test....donno fix though
1 - 2 of 2 Posts
