1 - 5 of 5 Posts
So I have had my E36 328 for 2 years now it’s got 199k miles been a great car did all the usual suspects valve cover gasket plugs plug wires etc... got in the other day to go to work everything turns on has plenty of power (battery) just won’t even click or turn over I hear that it could be the chip reader for the key anyone have any thoughts??
Manual or automatic transmission?
More likely bent clutch interlock bracket or dead starter.
The e36 does not like to turn over with a low battery. Try the easiest thing first and put the battery on a charger for a while or give it a good jump start. If you try a jump start and at first it does not work, leave the good car running for a while hooked up to the e36. A really dead battery or a car without enough juice will not let the e36 start right away.
1 - 5 of 5 Posts
