1 - 6 of 6 Posts
Hello,
Can't figure out where is problem. Speed not shown on cluster and not working abs/asc.
im scanned errors with INPA.
Errors from engine:
Code:
1280  Fahrgeschwindigkeitssignal
Error frequency : 37 Logistic counter: 40
Fehler momentan vorhanden
sporadischer Fehler
Fahrgeschwindigkeit von CAN ungueltig
Errorcode: 05 00 28 25 FC 20 1D 79 4E 00 72 AD 20 00 4C 4D           00 72 C6 20 00 4C 4D 00 72
Code:
7680  CAN-Bus
Error frequency : 51 Logistic counter: 40
sporadischer Fehler
Empfangsfehler ASC
Errorcode: 1E 00 28 33 FC 02 1E 78 18 00 72 AD 02 00 64 40           00 72 C6 02 00 64 40 00 72
Errors from ABS module:
Code:
52    ABS Ventil Einlass hinten rechts
Error frequency : 254
   Fahrzeuggeschwindigkeitc 6.25  km/h
   ASC passiv geschaltet
   ABS-Regelung passiv
   BLS nicht betaetigt
   ASC-Regelung passiv
Code:
51    ABS Ventil Einlass hinten links oder Hinterachse
   Fahrzeuggeschwindigkeit 6.25  km/h
   ABS-Regelung passiv
   BLS nicht betaetigt
   ASC-Regelung passiv
Sometime speed show again. Example every morning until re-start engine then again stop show. Or sometime start show when drive to hill.
What i tryed?
* Change left side abs sensor.
* Change abs module.
* Change abs pump.
Any suggestions? :D
Well, what year is your car? On my car the speedo gets signal from rear left speed sensor, cruise control is rear right.
Have you checked all sensors wiring, they tend to deteriorate and wires will touch one another.
Discussion Starter · #4 ·
abs module 001.
some time when force turn to left it start show speed again. And problem not in left abs sensor.
Maybe abs module fault
1 - 6 of 6 Posts
