From the photo you uploaded, it looks like your Oil Filter Housing gasket is in need of replacement! You have to remove a few items, but overall not very difficult! I would say no more than a 2-3 hour turn around. The alternator has a "sleeve" on one side, if I remember correctly, where the bolt goes through...It's a very tight fit when you place it back in the bracket, so to save yourself the hassle of wrestling with it, simply tap that said sleeve out a bit,it could be in, it's been a while and that sucker will slide right in! When you tighten her up, it will move right into place. Good Luck!
