1 - 2 of 2 Posts
Dinan CAI $400 (must have airbox for a swap)
taken from dinan's website:
Part #: D760-0620
Price: $599.00
Labor Units: 30.0
Emission Status: 50 State Emission Legal
Required Products: Stage 2 Engine Software ($599.00; Part #D903-445TU2)
Peak Horsepower Gain: 13 @ 5700 rpm
Peak Torque Gain: 12 lb/ft @ 5700 rpm
Point Value: 2
Dinan High Flow Cold Air Intake Systems develop horsepower and torque gains by improving the engine's intake air flow. The aggressive system design provides for a less restrictive intake than the stock system for greater engine efficiency and the lowest possible intake air temperatures.
The High Flow Cold Air Intake Systems replace the factory air box with a cylindrical performance filter and large diameter aluminum intake plumbing, designed to minimize air turbulence and maximize efficiency.
The filter is relocated to a separate compartment behind the front bumper and below the headlights in order to insulate it from engine compartment heat and maximize exposure to cool, oxygen rich air for maximum power gains. The Stage 2 version of the Dinan Performance Engine Software is required in order to optimize the fuel mixture and ignition timing for optimum performance and driveability.
Dinan Strut Bar $390
Part #: D180-0390
Price: $549.00
Labor Units: 5.0
Point Value: 2
Dinan Strut and Shock Tower Braces help to maintain the structural integrity of the towers over the life of the vehicle as well as providing sharper handling by reducing flex under harder cornering conditions. The attractive brushed aluminum and carbon fiber braces may be installed in conjunction with any of the Dinan Suspension Systems or the stock components. The end brackets are machined for precise fitment over the strut tower reinforcements for a clean and solid installation.
Dinan Software $350
(must have ECU for a swap)
Part #: D900-445TU
Price: $499.00
Labor Units: 5.0
Special Notes: Various Stages of Performance Engine Software are available for specific product configurations.
Peak Horsepower Gain: 9 @ 4500 rpm
Peak Torque Gain: 11 lb/ft @ 2000 rpm
Point Value: 2
Dinan Performance Engine Software unleashes more power by re-programming the fuel mixture and ignition timing parameters of the engine management system. Furthermore the software safely raises the rev-limit, giving your BMW a broader power band and greater road speed potential in each gear. Significant gains are also achieved at part throttle, making extra power available where you spend the bulk of the time driving. The top speed governor has also been eliminated, enabling the vehicle to achieve it's "natural" top speed.
Discussion Starter · #2 ·
Strut Bar has been sold!
Dinan CAI and Software remain.
Software has a price cut of 50% due to the fact that on the Dinan homepage all their softwares and chips have a 50% cut as well.
1 - 2 of 2 Posts
