21 - 40 of 67 Posts
· Wingnut
are you getting CEL or has the DME been read for codes? if any codes, make note of em and list on here, then clear em and see what comes back. kinda hard to tell just by symptoms, different things come to mind from your post. read or have em read by a BMW specific scanner, many generic OBDII readers wont pull up pending or inactive codes, those can and probably are important.
· Registered
Welcome . I suffered from these problems as well, and I checked with a scanner, and the malfunction was the oxygen sensor, and I replaced it with this, the operation did not improve, and I checked the spark plugs and their connections, and cleaned the fuel injectors. Well, this is something crazy. According to my personal opinion, there is a sensor or a piece that works when it feels Warm only
· Registered
My 2002 530i simply won't start below 45 degrees F. What are the usual causes of this? It starts instantly when it warms up, so I am not sure where to look. I already paid the mechanic to replace the mass airflow meter, the oxygen sensors...so that did not work. I'd like to save money by trying less expensive solutions! Any ideas?
· Wingnut
hard to give a definitive answer from a distance. however i have experienced an intermittent hard start ( dunno if temp came in to play) from a cam sensor, replaced it no other issues since. the cam sensors are a semiconductor device, and can become temp sensitive. in your post #27, you stated that your mechanic was replacing the cam sensor(s). did this not happen? and btw, only replace with OE or OEM parts. many aftermarket parts dont work reliably, last long, some even arrive DOA.
· Registered
Hello all, to-date, the mechanic has not fixed my issue.
He has completed all of the following repairs:
  1. replaced two oxygen sensors
  2. replaced the mass airflow meter
  3. replaced both camshaft sensors
  4. replaced the crankshaft sensor
  5. replaced the fuel filter
  6. air mass meter boot which was cracked
  7. brake vacuum valve which was cracked
I arose early this morning to cold start my 2002 530i and it won't start at 45 degrees F.
What else could the issue be?
The vehicle starts and runs perfectly when the ambient temperature is warmer.
21 - 40 of 67 Posts
