1 - 5 of 5 Posts
Hi there
My E46's handbrake warning light (!) is illuminated red and is on constantly.
Handbrake switch tested and works fine. Brake fluid is topped up to the correct level.
What else could it be? No other lights are illuminated on the instrument cluster.
Is it Trackday yet?
Noone Special
Is the DSC light on as well indicating a issue with your ABS system? Is the brake pad warning light on indicating you need brake pads/rotors? Will get a red brake once the second stage of the brake sensor is tripped.
A Picture would help with all the lights lit up in the kombi
1 - 5 of 5 Posts
