1 - 3 of 3 Posts
MO Bimmer
So I have a high performance battery and the terminal is a little loose. Yesterday when I turned the key to start the car it went totally dead--no power. I tightened the battery terminal more and it worked perfect. Now the windows wont go up or down and my wipers doesnt work. Also, the blinker signal on the instrument cluster does not work-but the blinkers do work on the outside. Did I possibly blew a fuse? I checked the fuses 30A-that was linked to front and rear window lift and it was ok. I cant seem to figure out what fuse that might have blown or if it might have damaged some other electrical unit in the car. Any ideas? Suggestions?
MO Bimmer
Discussion Starter · #3 ·
I disconnected the negative terminal for 20minutes and it reset the computer.Now everything works good. No fuse was blown.
1 - 3 of 3 Posts
