1 - 1 of 1 Posts
My top will open but needs a small push in the front when it starts to fold it into the storage bin and then it will complete the opening sequence. On Closing the reverse its true. Once the cover opens and it starts to lift the top from the bin it needs a little pull on the front end and then it will complete the sequence.
Last year I changed the hydraulic pump and I have no leaks at present.
I'm thinking it may be the hydro unit again even though not likely because it was changed less than a year ago.
I'm wondering if there is such a thing as an internal cylinder failure where the fluid leaks inside the cylinder therefore not holding the pressure on the correct side?
Anyone has had any experience with this?
1 - 1 of 1 Posts
