1 - 6 of 6 Posts
Just rec'd the following 2 errors on my 01' 325. The P1345 appears to be a problem w/ the #2 cylinder (coil or plug). The P1619 isn't as clear. Lookup shows this a MAP cooling control circuit low. I've done a search and have only found one thread concerning this error. In their case, it was a thermostat. Could someone please provide some expertise w/ this error? Is that the only item that could throw that code? Car has not been over-heating. Thanks.
So, can we say that P1619 it the thermostat for sure even though the car never overheats?
I got a 2001 325i with that same code giving me the Check engine soon light
I changed the stat, cleared the code and haven't had a problem since. Oh, my temp never varied either, pegged right in the middle, so I guess the stat was OK in it's operation but sending the wrong info to computer.
1 - 6 of 6 Posts
