1 - 3 of 3 Posts
Hello. In my E53 obd shows camshaft position sensor fault (exhaust side). Found part number, bought it, installed it and fun started. All cylinders started to missfire, system too lean and rpm drops low. But when I put back old sensor, everything runs almost fine and no missfires. You can feel that engine dont work properly, but no missfires and you can drive. Strange that this sensor with the same code looks different.
This is the old sensor that is installed and shows fault code. I cant find the same sensor like this
Discussion Starter #3
I bought Mayle and Valeo brands both some result. Found one BMW brand, same as the is installed but it's used and price same as new.
1 - 3 of 3 Posts
