Good day all!! I selected "ALL BMWs" as I didn't have E53 as an option in the Prefix... Hope this is okay!!!
The story: I got my 2004 4.4L X5 sport needing an engine... I rebuilt it... Air suspension didn't work, so I swapped over to coil springs... Error message on display was annoying... Fixed that with help!!
I had a faulty Bosch valve body module in the ZF 6HP26 transmission... Bought a 2006 X5 transmission... BUT I didn't realize it was from a NON-SPORT version X5... So, now I have a trans failsafe because the X5 doesn't see a SPORT version valve body module... I have checked both modules... They are the same part number... The chip part number is even the same... Obviously the serial numbers are different as are the production dates...
I have searched for days on all the forums concerning the E53 and have gotten a lot of help from the experts that dedicate their valuable time to assist those of us that are new to this coding... I have the INPA and NCS Expert working... Thank you SHAWN!!! I turned off my DRL's and got rid of my RIDE SUSPENSION FAULT message on the instrument cluster (by accident; I found the display option AIR SUSPENSION for the message in the LCM; toggled to NOT ACTIVE and no more message without doing anything else)... But I am not able to locate the specific answers to my new concerns... I want to verify I'm doing this correctly so I don't make the X5 worse...
Having stated all that, my questions are.......
Do I need to put my old valve body module back in the vehicle to get the info from it and saved on my computer to program the new module?
Is there a SPORT setting in the coding (using NCS Expert) that is now NOT ACTIVE with the new trans module, and coding that to ACTIVE will correct this issue?
Do I have to "CODE" the module or just "UPDATE" it with WinKFP? Do I need to get correct information from the old module first?
Essentially, What coding or programming is required when a transmission is replaced, using what software?
Thanks so much!!
Cheers!!!
Thanks so much!!
Cheers!!!
