Hello, I have a pre-LCI e60, and a couple of months ago I have changed the cd radio to a newer version because the old one died (I had the one without cd numbers below it and switched to the newer one with CD numbers (1-6), the new one was coded and everything worked fine EXCEPT one thing that I never noticed before. The actual way where air should be distributed is not working, I move the knob to left or right but it just doesn't respond to it. There are no errors, except for one regarding some temperature sensor but other than that car is making no problems everything works fine regarding CCC, the only thing is air distribution, and the strange thing is i can control kinda air distribution by moving the temperature knob and lowering it actually moves, here check it out :
Should I maybe change the climate as well to match basically the newer version of CCC or what?
