Fuse Layouts and Wiring
Reference: 645Ci Fuse Layout (Link by TopDownInFL)
Reference: Fuse Layout
_
Reference: 650i Fuse Layout (By coug60)
Fuse Diagrams Here
_
Reference: M6 Fuse Layout (By whatheheck (M5Board))
M6 Fuse Lay Out
_
Wiring Colours PDF added below
_
MOST BUS Faults
MOST BUS (Fibre Optic Cable) fault diagnostic chart in PDF form below.
_
iPod/iPhone / AUX/USB
iPod interface installation DIY (By schulrog)
E63/64 DIY: iPod interface installation DIY
_
Adding USB port to center console (By Ross Leidy)
_
Phone tray mod (USB) (By rilot)
Phone tray mod
_
Custom Phone mount...no wires (By pmorrone)
www.bimmerfest.com
_
AUX Install - See Vids Below
_
Amp
Logic 7 diy amp repair (By wizzi07)
E63/64 DIY: Logic 7 diy amp repair
_
Aftermarket sub/amp DIY (By 30yrVeteran)
_
Possible fix to moisture issue for amp (By tizre1)
Possible fix to moisture issue for amp.
Also see Drain DIY's under E63/64 - Body
_
My Audio build thread "Updated 28 Apr 2014" (By
All-Or-Nothing)
_
Speakers
DIY - Earthquake under seat speakers install (By 30yrVeteran)
_
M6 Center Channel Speaker Replace DIY (By whatheheck (M5Board))
Also see "M6 Center Speaker Replacement" PDF at the bottom of the thread
_
M6 Door tweeter replacement (By whatheheck (M5Board))
Also see the "M6 Tweeter Replacement" PDF at the bottom of the thread
_
CCC / CIC / NBT
CIC Retrofit for BMW E63s (By AlexMSFT)
E63/64 DIY: CIC Retrofit for BMW E63s - (Long and Pic Heavy)
_
What it really takes for a CIC retrofit.. (DIY, Complete! Coding files included!) (By schpenxel)
What it really takes for a CIC retrofit.. (DIY...
_
CiC Retrofit (Info) (By Carter650i)
CiC Retrofit
_
Reference Only: e90 CCC and CIC to NBT retrofit DIY (By TarveN)
_
Reference Only: DIY - E60 NBT retrofit diversity antenna (By 2real4u)
_
SOS MALFUNCTION (Fix) (By DropSixx)
E63/64 SOS MALFUNCTION (Fix)
_
BMW SOS Error / Malfunction Cheap FIX - Wow it really worked! (By oRIDDLERo)
BMW SOS Error / Malfunction Cheap FIX - Wow it really...
_
Professional Satellite Navigation (609A) Retrofit - Project ( By Rebel.Ranter )
_
Alarm System
Backup Battery Replacement (By rebel.ranter)
E63 Alarm Siren Error code 9D12
___
Misc
BMW E63 and E64 6-Series, how to fit a remote-controlled WiFi Dash Cam (properly) (By Timm)
Timm's BMW 6-Series E63 E64 WiFi Dash Cam Fitting
_
DIY - Spare Key enable / disable in DIS (By Mulchman)
_
DIY - Comfort Access Battery Change (By msa9167)
_
Ski Bag retrofit (By RooK77)
E63/64 DIY: Ski Bag retrofit
_
Videos
Aux Install and Coding
_
Fuse Diagrams Here
_
M6 Fuse Lay Out
_
_
MOST BUS Faults
_
_
_
Phone tray mod
_
Custom Phone Mount...no wires!
I went from a newer generation car to a 2007 650i conv. and miss the modern electronics. Have no bluetooth audio in my BMW..just phone support over BT. I have been using my phone for navigation primarily as google and waze are so much better than the old school car nav. I did have an aux...
_
Amp
_
_
_
All-Or-Nothing)
_
Speakers
_
_
_
CCC / CIC / NBT
_
_
CiC Retrofit
_
_
_
_
_
_
Alarm System
___
Misc
_
_
_
_
Videos
