Status
Not open for further replies.
1 - 1 of 1 Posts
Super Moderator
BMW Wheel Model Specs
BMW wheel designs and measurements
All BMW wheel styles | BmwStyleWheels.com
_
Tyre and Wheel Calculators/Info
http://www.alloywheelsdirect.net/information/fitting_chart/bmw
BMW 6 Series - Specs of wheel sizes, tires, PCD, Offset and Rims for all model years
http://www.wheelsizecalculator.com/resultlist_wat_size/?brand_id=15&model_id=1105&x=82&y=14
https://www.willtheyfit.com/
Tire Size Calculator
__
Wheels
DIY: How to Measure Wheel to Fender Gap for Wheel Spacers (By Yorgi)
_
Front bearing replacement
(By taivorokib)
_
wheel bearing on 645ci info
_
Chassis
E60 Chassis Steering Information PDF added below (Not E64/64 Specific)
_
Sway Bar/ Active Stabilizer Hydraulic fluid Leak (By pkathee)
Post No.6
_
Everything you didn't want to know about your Dynamic Drive DIY Valve Block
(By wilson009, forwarded by FredoinSF)
Resource -Everything you didn***8217;t want to know...
_
645Ci ARB Link Replacement
(By Hsurf)
E63/E64 DIY: 645Ci Front ARB Link Replacement
_
645Ci Front Upper Control/Thrust Arm
(By Hsurf)
E63/E64 DIY: 645Ci Front Upper Control/Thrust Arm
_
645Ci Front Lower Control Arms/Wishbones
(By Hsurf)
BMW E63/64 645Ci Front Lower Control Arms/Wishbones
_
Suspension Spring Part Numbers
E63/4 Part numbers added to the PDF's below, these are for all models both pre and post LCI except the M6 and are based on UK and US models.
_
05 645ci Front/Rear strut build video
(By FL05645ci)
_
E63 M6 Diff swap into 645ci
(By sixshooter645)
E63 M6 Diff Swap into 645Ci
_
Videos
How to properly put an F30 BMW on Jack Stands (Same for our cars) and Upper Control Arms
_
Wheel Offset
https://www.youtube.com/watch?v=8EvMdbWB6MA
1 - 1 of 1 Posts
Status
