Status
Not open for further replies.
1 - 2 of 2 Posts
Super Moderator
Fuse Layouts
Reference: 645Ci Fuse Layout (Link by TopDownInFL)
Reference: Fuse Layout
_
Reference: 650i Fuse Layout
(By coug60)
Fuse Diagrams Here
_
Reference: M6 Fuse Layout
(By whatheheck (M5Board))
M6 Fuse Lay Out
_
Servicing
DIY Microfilter Change along with Lower Housing Removal (By tampamark)
_
Oil Change and Check Control Reset
(By Yorgi)
E63/64 DIY: BMW 650i / 645Ci Oil Change and Check...
_
DIY - Oil Change with Pics
(By bimmerzone)
_
DIY Spark Plug change - with illustrations
(By tampamark)
E63/64 DIY: Spark Plug change - with illustrations
_
DIY air filter k&n!
(By buronan)
DIY air filter k&n!
_
Engine
Common Problems link
https://europeanedgeoftallahassee.com/blog/common-issues-with-bmw-s-n62-engine
_
Cylinder Head Attached Parts
Engine Oil Level Switch Replacement (This doubles up as an Oil Level, Temperature and Quality Sensor)
PDF Added at the bottom of the page
_
Upper Timing Case
Changing vanos solenoid o-rings on the n62 engine (By gk73a (Bimmerforums UK))
changing vanos solenoid o-rings on the n62 engine
For reference and fault finding help
FIXED!!! Did a bunch of repairs and now CEL, DME errors P0021 and P0024 and misfires - Xoutpost.com (By X5only (Xoutpost.com))
BMW VANOS System Design & Common Faults (Autologic.com)
It should be noted to ensure the solenoids are seated all the way in, typical codes that can be thrown are timing codes and can be found at the bottom of the Autologic link.
_
Cylinder Head Cover
DIY: BMW 2005 645Ci / E63 / Crank Case Vent Valves CCV (By bigtyme562)
E63/64 DIY: BMW 2005 645Ci / E63 / Crank Case Vent...
_
E63 E64 N62 V8 Valve Cover Removal W/ Pics DIY
(By Sick645ci)
Also see Removing and installing Timing Case and Cylinder Head Cover PDF's linked at the bottom
_
Reference Only: N62/E65/E66 Valve Stem Seals Replacement, Valve Cover and Timing Chain Case Gasket
(By Knight's Master Tech)
N62/E65/E66 Valve Stem Seals Replacement, Valve Cover...
_
DIY Increased Emissions Gas Cap fix
(By Skarv)
_
DIY: DMTL Pump (Increased Emissions - code 1434)
(By Skarv)
_
Everything you didn't want to know about your Dynamic Drive DIY Valve Block
(By wilson009, forwarded by FredoinSF)
Resource -Everything you didn***8217;t want to know...
_
645Ci Fan Removal
(By Hsurf)
E63/E64 DIY: Cooling Fan Removal
_
Waterpump - Thermostat
Thermostat Replacement ***8211; CE and loud aux fan issue fixed (By oRIDDLERo)
Thermostat Replacement - CE and loud aux fan issue fixed
_
DIY for thermostat
(By Skarv) Written directions, post no.2
DIY for thermostat
_
Thermostat modification
(By HULKED)
_
Cooling System Pipe
Coolant Leak Repair (Cap w Seal and Expanding Coolant Pipe) w Pics (By Bmwaudivwdude)
E63/64 DIY: Coolant Leak Repair ( Cap w Seal and...
_
Vacuum Pump
BMW E63, E64 N62 Engine Vacuum Pump Oil-Leak Fix (By Timm (Bimmerforums UK))
_
Videos
N62 Engine Oil Change and PCV Valves
BMW Replacing Coolant Transfer Pipe N62 and BMW Replacing Timing Cover & Valve Cover Gaskets N62
N62 Engine Build Part 1 and 2
https://www.youtube.com/watch?v=UTdCUJEw5lM&list=LLMWMDlHDKC_KrhSp7mt-Wbw&index=3&t=456s
1 - 2 of 2 Posts
Status
