Transmission
Fluid change PDF's (Forwarded by FredoinSF and HerbP)
Transmission overheating
___
Sonnax PDF'sSonnax Webinar for Valve body repairs
Sonnax Webinar: ZF6 Gen. 1 & Gen. 2 Identification & Repair Techniques
____
Transmission pan, filter, and partial fluid change, Done. (By oRIDDLERo)
____
ZF6HP Info and links (Forwarded by FredoinSF and lpcapital) Post No.2
Transmission Service
____
6HP26 Parts catalogue + fill procedure PDF added below
____
6HP19 (As fitted to the 630i) Parts catalogue + fill procedure PDF added below
____
Drive Shaft
BMW 6-Series - Transmission thunk fix - Guibo / Flex Disk (Info By oRIDDLERo)
____
Differential
Fluid change PDF added below. Fill levels for the various Diff's also included.
____
Vidoes
ZF 6HP Transmission Oil Change Interval Procedure / Diff Fluid Change (Single Drain/Refill Plug)
Diff Fluid Change (Dual Drain/Refill Plugs) Note: Undo the Fill plug first then the Drain
___
____
____
____
____
____
Drive Shaft
____
Differential
____
Vidoes
