1 - 4 of 4 Posts
Hi everyone,
do you know if a set of E65 wheels will fit a E63?
I have an offer for a set of Style 92 forged wheels, but they come from a E65 and the sizes are a bit different.
Wheel Sizes:
Front: 19 x 9 ET24
Rear : 19 x 10 ET24
The car is full stock :)
Thanks,
Joao Completo
You will need to use spacers with those wheels - 10mm (safe) to 15mm (aggressive) at all 4 corners.
The tire size on the 7-series is also a little larger than what the 6ers use - by about 4% - so you can use the tires on the wheels for now but when you go to replace them change the tires to 255/40R19 front + 285/35R19 rear or 245/40R19 front + 275/35R19 rear.
Discussion Starter · #3 ·
Hi Yorgi,
thank you for your feedback! I went to the tyre shop and they said it would fit! They took the measures and confirmed it would be fine! I have them now on the car, but based on your feedback, I'll probably buy the spacers! The tyres that comes with them are the "correct" size for the 6 ...
An image of them fitted:
The danger is that they don't have enough play space on the inside right?
THanks!
...The danger is that they don't have enough play space on the inside right?
THanks!
Stock offset is 14mm front and rear which is why I suggested 10mm to return those wheels to stock offset.
You are correct, at ET24 the inside of the rim will be very close to the shock. If you take a look I bet they are almost rubbing on the shock. Also, looks-wise people tend to add spacers to improve looks by pushing the wheels out past stock offset. With ET24 you have the opposite situation - the wheels are "tucked-in" which makes the car look anemic to me.
1 - 4 of 4 Posts
