My E70 X5 4.8i (81k) having some issues this week.
- Sign comes up for 4x4 and Transmission malfunction goes in a limp mode. Drive slowly to home and Stop the Car, then restart and everything looks good. Did notice that Date was gone and thought it might be the Battery or Alternator or Voltage Regulator . Did observe Battery was 11.5V so charge the Battery and it come to 12.5V and 14.6V with engine running.
- Same thing happens again and this time it took a while to start the Car again, so thought of Alternator/Battery again. Took to the Indy and he said he sees no issue with Battery (3 yr old) or alternator.
- Third time it happens again, this time I Drive the SAV to the Indy (3 mile) couldnt put the SAV in "P" so have to pull the Parking Break. While mechanic was looking at the Codes with his PC hookup smoke started coming from under the hood and saw Radiator fluid start leaking underneath the SAV.
I was told I have a Expansion Tank leak and a potential Water pump problem and may be more things and they still looking at it and will let me know on Monday. My question is why My AUX Fan was not running and why No Over Heat sign if its the Water Pump or Thermostat.?? I keep thinking its the Alternator since Date/Time keep going away every day.
So keeping my fingers crossed I hope its just the water pump and not the Engine. My Indy only put Genuine BMW parts and give same Warranty as Dealer do. So not sure how much will Expansion tank and Water pump/Thermostat will cost Plus Labor.
