The pads fit snug, I've checked that. The lubricant wouldn't have gotten on the pads since I did not apply a whole lot. I guess I'll find out this weekend how're the brakes looking. What brake parts lubricant did you use?
I haven't actually done a brake job on this car, but was going by past experience. Recently did my daughter-in-law's brakes using Brembo ceramic pads. Impressive kit, which included a good-sized tube of high temp lithium grease. Also have a tube of Raybestos grease in the garage which is a moly-based grease. Have never had any issues with frozen brakes parts using any of these products, nor have I considered any squealing to be an issue with brake part lubricants. The brakes on my car are mostly quiet with the exception of backing up with cold brakes which produces a not too obnoxious squeal. No noise once warmed up. Have a feeling your situation is still a high frequency harmonic vibration between the rotors and pads.
Thanks for teh details. My brakes do a VERY obnoxious sounds for the first 2 minutes of driving in the morning (backing up and then driving), then it goes away. So, if my case is not an issue of lubrication, but of high frequency harmonics, what would be the causing it? Loose fitting pads? More importantly, what would be the solution?
Most pads use spring tension or clips to hold them tightly in the calipers, and many kits also include the cushioning goo to spread on the rear of the pads for even more stability.....................
The Europeans tend to laugh at us Americans when it comes to brakes. They say that we would rather have a car that was quiet and didn't stop vs. a car that makes a little noise but stops well.![]()
When nothing else works chamfering the pads does help.
I have done this with some sets of pads that would squeal even with brake pad vibration goo and everything else perfect.
