Exactly what power source and/or fuse do you have your audio amplifier connected to?
If you are pulling power from any source using Terminal 15, then you may need a new CAS module...ensure that your amplifier is wired directly from Fuse 42 (40A) powered by Terminal 30.
Take your amplifier off line, then post if your car recovers it's proper operation.....if so, then let's wire up your amplifier correctly in your vehicle...on the other hand, if your car does not recover after removing your amplifier, you may need to seek professional help.
Although "red" wires may be in the vicinity of your amplifier location, it's almost never OK to tap them for +12VDC...
What is your battery voltage when the car is off, when the car is in accessory mode, but engine not running, and when the car engine is running?
ALL of the Fault Codes you list, including the KOMBI Message Error, NO Message from CAS, COULD be caused by interruption in the CAS Power Supply. They could also be caused by an internal fault in the CAS Module, but always start with the cheap, simple stuff, in this case fuses: F36 (40A) & F55 (5A). Attached are ISTA wiring diagram and Fuse Locations for F36 & F55.
If the symptoms happen again, listen carefully for "Click" or even "Chatter" (ratchet-like repeated clicking) from the glovebox area, which would suggest KL15 relay contacts failing to remain closed. The KL15 relay is soldered to JB PCB, rather than plug-in, but I can't recall a knowledgeable report of failure of that relay. The Connector (X11010/6) is therefore 1st suspect.
The CAS Module Activates the two Relays, shown as IO1068 ("Accessory" or 30G Relay) and IO1069 (KL15 or Ignition Relay) on the attached wiring diagram. The KL 15-3 circuit powers the Headlight Switch related to FRM, hence the FRM code. So if CAS Power Supply is interrupted, as you describe Ignition is turned off, same as if you pressed STOP. The fact that it is just momentary suggests a loose or corroded connection, perhaps at the fuse panel, or at the CAS Connector X13376, or an internal fault, such as a cracked solder joint, in the CAS PCB (Printed Circuit Board).
I would begin by removing the two CAS fuses, & cleaning the fuse spades and sockets. Sockets are "Live" on one side as both are UN-switched battery power (KL30) as indicated by the small "30" over each fuse symbol on the SSP. If symptoms persist, I would disconnect X11010 at the top-left of JB (Junction Box) Fuse Panel, and carefully inspect pin & Socket related to Pin #6, Green Wire, as that is KL15 Activation wire from CAS Module.
If you had INPA or ISTA, you could view the voltage of ALL of those Terminals and the Hall Sensors as Live Data. Probably would NOT add that much however, as the fault codes tell the story rather clearly if you understand the circuits involved.
Anyone know what the two "Hall Sensors" (12 & 34) in the INPA "Diagnose Terminals" Screen relate to?
If you have had any water in either footwell lately, let us know. Wet/corroded fuses or connectors, or even a bad ground, COULD cause the issue. Any work, such as Blower Harness Recall, been performed in either footwell recently? No wiring changes or changes in Amp wiring?
George
View attachment 1053980 View attachment 1053981 View attachment 1053982 View attachment 1053983
Stereo Board on e90post reports that you will start to have electrical problems when running
aftermarket stuff over 2000 watts. I have been running a JL 600/6 for years with not problems
but it is only a 600watt amp that probably runs at much less than that. Also it's hooked up to the
battery tightening lugs with 04 wire.
Updating so if anyone has similar issues
I noticed if I wiggle my key fob while the car is running, sometime it will trigger it to shut off, it's more rough then what the car does by itself. So I'm gonna be replacing the key fob reader and seeing what it does for me. The terminal 15 codes came back. I believe these are the same ones that it kept bringing back up
A0BE: CAS terminal 15 output 1
A0BF: CAS terminal 15 output 2
A0C0: CAS terminal 15 output 3
Did you ever get this fixed? I am having the same issue on my 07 335i
Me 2 did you figure it out?
