e90 eps vin change
332 Views 11 Replies 5 Participants Last post by  TheNine90
hi
im am trying to change the vin on a used eps unit with winkfp but it is not showing any vin so it wont let me put my vin in.
tried tool32 but comes back as error (see pic)
anyone able to help with this
Product Rectangle Azure Font Screenshot
1 - 12 of 12 Posts
Check winkfp settings. Box checked for comfort mode uif write
hi thanks for the reply
box is checked but still cant write vin as replacement eps is not showing a vin to replace
That is impossible. If you checked the right box, you have there the button to press and write vin. Post screenshots
screenshot from inpa
Rectangle Font Software Parallel Screenshot
then when i try and write vin in winkfp
Product Rectangle Font Screenshot Technology
Rectangle Font Screenshot Parallel Software
Product Rectangle Azure Computer Font
looks like the error is coming because there is empty zusb places in winkfp.
what happens when input "enter zusb"?
As a matter of fact, i have seen lot of bmw with empty vin in inpa uif section. I suppose this must be normal.
Side note, I wasn't aware any E90 came with EPS? I thought they all had hydraulic steering...
-E- after looking it up, looks like other markets had some variants with EPS. Not the US market I am familiar with though.
I think you need FSC codes for the EPS. Maybe that is causing your issue?
hi i think you may be correct do you know where to get the fsc code from
Maybe ask in the programming/coding section of this forum.
what fsc has to do with programming vin?
Try coding it using NCS expert. It should write the vin
1 - 12 of 12 Posts
