1 - 4 of 4 Posts
Hi,
I need help with my son's car , the car is 2006 328i after 30 min parked then it will crank but no start , throwing those error codes p2080 and p 2090 p0341 and bad thermostat , the care kind of lost power right before parked , we changed the cam position sensor and the two vanos solenoid ( parts from autozone) the CPS code went away (on and off) but the other errors still and the care will crank but no start , also tried new battery but no luck , would it be the thermostat ? thanks for all the help.
3/2007 328xi E91
,,,I need help with my son's car , the car is 2006 328i...
QUOTE=lazezo;12845639]Anyone ?[/QUOTE]
Since someone posted ~ 1 hour earlier than you yesterday evening, and correctly identified the 2006 model as a 325i, I responded to him -- I presume either (1) your son posted, OR (2) you are BOTH trolls posting duplicate complaints of same 3 codes. :)
Here's the link to that thread -- I realize you probably are used to the 740i Forum:
https://www.bimmerfest.com/forums/showthread.php?t=1308647
George
1 - 4 of 4 Posts
