1 - 4 of 4 Posts
I have a Australian delivered 2010 BMW 320d Lifestyle (E90) with 72,000km. I have a strange problem with the transmission neutralising while waiting at traffic lights when cold. When I sit for a while and release the brake pedal there is no drive for a second then it thumps into gear. It only last for the first few minutes then stops when it warms up.
I spoke to a transmission specialist who I know, and he says that is how the double clutch transmission works but I spoke to my BMW dealer and they didn’t understand what I was talking about, or the service advisor didn’t (who wasn’t a mechanic).
I have since been told there is a timer setting which can be adjusted to control this problem, i suspect by plugging in a laptop. Does anyone have knowledge of this issue?
Thank you,
Justin
From what I understand, the dual clutch transmission (DCT) is not an option on your car...... The only E9x equipped with it is the 335is, and only in certain years. I could be mistaken, and AU cars might be configured differently (I did a quick Google search and didn't see anything to that effect though).
I have driven DCT cars (as recently as a couple months ago) and I can tell you that I absolutely don't believe the transmission should be thumping into gear, or have a lag when pulling away from a full stop. In my experience driving DCTs, this has not been the case.
Discussion Starter #3
Thanks Yukoner,
I'm certain it is not normal and the dealer just didn't drive it cold enough to reproduce the fault.
Fingers cross somebody else has knowledge of it.
I'm assuming you have the 6-speed automatic transmission.
You probably need to at least drain/replace your automatic transmission fluid and filter. Worst case you may have some broken seals and/or solenoids in there to replace. If you did it on your own it'd be around $300 all in, dealership will likely be more.
1 - 4 of 4 Posts
